NI TestStand
Property Loader Database Plugin - Properties Versioning
Hello to all TestStanders
For my Testsequence I want to load the e.g. the Limits for a test from a database with the "Property Loader Database Plugin".
I could export the properties successfully to the database an implement the property Loader in my Testsequence.
Now i have the requirement to generate a new version for my properties (e.g. Limit change).
It should be possible to jump back to the old properties if something went wrong.
So what I need is a Versioning of my properties:
PartA_Lim_V1.0.0
PartA_Lim_V1.0.1
PartA_Lim_V1.0.2
To Versioning my Properties I used the "Property Loader Groups" and created for a new version a new Group and exported them to the database:
On the Property Loader I added Preconditions to determine which Group should be loaded (In the local "properties_version" is the Version to used stored eg. "1.0.0":
"$(GroupName)" == RunState.Root.Locals.UUT.PartNumber + "_V_"+ RunState.Sequence.Locals.properties_version
This solution seems to work but I'm not sure how maintainable it is.
I'm new to TestStand and not sure if I use the Property Loader like it should be used.
I'm Interested what you think about my solution and how you implement something similar?
Best regards
Pascal
(1,495 Views)
Hi all, nobody has the same or a similar requirement?
Best regards
(1,425 Views)
