NI TestStand
Programmatically run in Labview a Sequence with Process Model changing the parameters values
In a custom Operator Interface, while there are no running tests, I need to run a service sequence to control a mechanical panel lock by pressing a buttton on GUI.
This service sequence has one input ("Action") and one output ("Locked"). The "Locked" parameter is initialized to False before execution.
I can easily run the sequence without process model with the following code (run_sequence.png):
Since I need to log the sequence execution in TS SQL database, in order to trace operator's actions, this solution is not viable because without Process Model the NI_DatabaseLogger.seq is not called.
I can successfully run the sequence with SequentialModel "Single Pass" entry using the TS supplied example "Execute With Process Model.vi" but I don't know how to modify the client MainSequence parameters before execution and read them afterwards.
Reading the manual page:
https://www.ni.com/docs/en-US/bundle/teststand/page/managing-process-model-entry-points.html
was of no help.
Where can I find a code snippet to accomplish this?
Given it is possible, in the end...
Thanks for reading
Raffaello
(251 Views)
I have moved the in/out variables to FileGlobals scope and been able to set them before execution:
but the "Locked" output variable is always read to its default value, regadless of what sequence code writes in it.
(222 Views)
I have found out that I had to get the FileGlobals runtime copy if I want to be able to read the values set at runtime
I am sure there are better ways to do this, but at least it works.
Raffaello
(219 Views)
