NI TestStand
Programmatically creating local variable
I need to create a local variable of custom data type using a Statement. Which teststand API should I use?
(2,214 Views)
Hi Savitha242,
 If you want to write code in statement  to generate customized data, you could follow below pictures ~
Locals.NewSubProperty("Container ", PropValType_Container , False," ", PropOption_DoNothingIfExists),
#NoValidation(Locals.Container.SetValNumber("Number", PropOption_InsertIfMissing, 10)),
#NoValidation(Locals.Container.SetValString("String", PropOption_InsertIfMissing, "Hello World!!")),
Here is the result :
And if you already have the position where you want to generate data, you don't need to use #NoValidation ~
Ricky
(2,157 Views)
