NI TestStand
Programmatically changing tracing speed in LabVIEW
I was wondering if I can use tracing speed API in LabVIEW? I found that it's possible Enable/Disable tracing but not the speed rate.
Thanks in advance.
Dooyoung
Best Regards,
(2,706 Views)
Hi gooohestpoo,
This link suggests that you use UIMessageDelay Property to control Tracing Speed programmatically.  I have not tried it (yet) but might be worth giving it a go.
Additional:  I gave it a go.  I can control the Tracing Speed of an execution from within a running sequence using:
Hope this helps
Steve
(2,651 Views)
