NI TestStand
Programmatically Close TestStand Sequence
I am something of a TestStand novice, so apologies if this is a simple question.
Is there a way of programmatically closing a TestStand sequence on completion, or can I give it an instruction in its final step to close itself.
I would like the TestStand environment itself to remain running, I want to close only the sequence file in question.
Dan
Dan
CLD
(6,346 Views)
Accepted by topic author DanB1983
For closing the sequence file you can use a method of ApplicationManager called CloseSequenceFile.
You can obtain ApplicationManager reference out of the SequenceContext by getting its property Engine -> method GetInternalOption (InternalOption_ApplicationManger) -> cast it to IApplicationMgr class.
The easiset way to do that in TS is to use an action with ActiveX/COM adapter and set its settings like this. It should close the sequence file after its execution is over.
CLA, CTD, CLED @ Test & Measurements Solutions Poland
(6,340 Views)
