NI TestStand
ProcessModelPostResultListEntry is not called
I wrote my own ProcessModell. I want to generate a Report File after executing a customer sequence call in a client sequence file and I thought I could do this in the callback ProcessModelPostResultListEntry.
But during the execution Teststand does not call the callback and I have no idea why. It works when  I use the SequenceFilePostResultListEntry in the client sequence file, but I want have only one callback and not a callback in every client sequence file.
Has anybody an idea why Teststand does not call the callback ProcessModelPostResultListEntry after executing steps in the client sequence file.
Thanks so lot.
Kind regards
Matthias
(3,634 Views)
 In your process model, make sure you are calling Execution.EnableCallback to enable CallbackType_ModelPostResult–(Value: 0x3) ProcessModelPostResult callback.
Allen P.
NI
(3,625 Views)
Hi AllenP,
thank you very much for your help.
I copied the standard SequentialModel for my own model, and I did not see that the ModelResultCallback was disabled.
Kind regards
Matthias
(3,609 Views)
Matthias -
There is a call in the Setup step group of the Single Pass and Test UUTs entry points to disable the callback. See if you have that.
Scott Richardson
https://testeract.com
(3,601 Views)
Hi Scott,
yes, I had that and I skipped this step. Now it works very well.
Thanks for your help.
Kind regards
Matthias
(3,587 Views)
