NI TestStand
ProcessCleanup Not Called
What could be the reason for TesStand not calling PrcessCleanup sequence when I terminate the sequence execution?
I am using sequential model. I placed breakpoints in ProcessCleanup sequence and they are not getting hit.
CT
(4,732 Views)
Maybe you aborted and not terminated.
For termination all cleanup sequences are run including process cleanup.
For abort execution simply stops or aborts.
(4,694 Views)
CT,
did you active debugging during Termination?
Norbert
Norbert
Expert: Geometry
(4,692 Views)
