NI TestStand
Problems to show IVI driver, properts loader when using operator interface
I am using the Operator Interface (programmed in CVI, with asynchronous timer) in folder OP1 in attached  zip file. This operator interface puts not the error message of IVI driver, properts loader etc... on the screen (messages like in attached picture error.jpg in attached zip file). Because of stability problems I am using this operator interface but I need these error message.
A Other Operator interface is OP2 in attached zip file. This operator interface puts the error message of IVI driver, properts loader ... on the screen (messages like in attached picture error.jpg in attached zip file).
Now I want to have this functionality with OP1 becaus of stability reasons I have to use OP1.
How can I implement this in OP1? I tried and searched a lot of time but I have not found a method to implement this.
can anyone help me?
thank you
regards Samuel
(3,121 Views)
Hi Sam,
if you open the userinterface which comes with Teststand - the simple one - you should be able to find the difference. You can find it here:
C:\Programme\National Instruments\TestStand 4.1\UserInterfaces\Simple\CVI
 I hope this helps.
Greetings, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(3,011 Views)
