NI TestStand
Problem in Teststand Operator Interface
I am facing problems when i try to run my sequence file from TestStand Operator Interface for LabVIEW. It gives either all tests as failed or skipped but the same sequence file when i execute from TestStand Sequence Editor it gives me correct results. I am not able to figure out what is the problem?? Somebody worked with teststand operator interface please help me to solve the problem.
Regards
Subramania Bharathi.
(3,051 Views)
Which version of TestStand and LabVIEW are you using.
Are you using a Customised LabVIEW Operator Interface or are you using the default version?
If you can provide a example of your Test Sequence File to help identify your problem.
Regards
Ray Farmer
Regards
Ray Farmer
(3,051 Views)
