NI TestStand
Post Actions on failure with random sequence
I use the SequenceFilePostStepFailure callback to catch failing steps. This works great except for random sequences. On retry the next step in the random sequence will be executed and not the same step.
Can somebody help me to fix this?
Message 1 of 9
(3,822 Views)
You'll need to use something similar to this on retry in order to change which step will be the next to execute.
RunState.Caller.RunState.NextStepIndex = RunState.Caller.RunState.StepIndex
CTA, CLA, MTFBWY
Message 2 of 9
(3,808 Views)
I already increased the stepcounter in the post action only on when the step passed. But it still jumps to the wrong step after a passed step.
Message 3 of 9
(3,804 Views)
That callback is only being called on a failure so I'm not sure where your passing issue is coming from. You should probably step through the execution and note the value of RunState.NextStepIndex to see where it is being changed. Perhaps you have a Post Action doing something that it shouldn't in your code.
CTA, CLA, MTFBWY
Message 4 of 9
(3,800 Views)
Then I think it's a bug in the random step sequence. I need to follow nextstepindex.
Message 5 of 9
(3,795 Views)
without known whats generated in your random array it's difficuilt too offer any meaningful help or whether to say if you are suffering from a bug.
Regards
Ray Farmer
Message 6 of 9
(3,788 Views)
Ray, I provided my sequence file in the attachments. I don't know if it opens on all systems?
Message 7 of 9
(3,780 Views)
Thanks I did look that that but couldn't tell what's being gathered in the VI as no VI's available, hence the question.
I did try to make a working version of your sequence file with dummy sequences.
Regards
Ray Farmer
Message 8 of 9
(3,772 Views)
Ray, you may always send me this sequence. Tnx!
Message 9 of 9
(3,770 Views)
