NI TestStand
Pin Configuration Editor problem
How do I list all the test instruments within a new test sequence ? In other words how do I populate all the installed SMUs and connect it so that all pile up in the list within the drop down menu for Pin configuration editor please?
Thank you.
(1,482 Views)
You need to provide more context and explain your goals better.
Are you talking about NI TSM and STS?
Santhosh
Soliton Technologies
(1,471 Views)
Yes, talking about NI TSM and STS.
We are having problem with our STS System which probably could be due to an issue relating Update required for the Pin Configuration Editor in Test Stand 2020.
We have encountered a problem loading all the instruments (SMUs/DMMs) from the pull-down menu within Pin Configuration Editor in test stand 2020. For example , SMU 4147 happens to be installed but we are unable to see that instrument from the pull-down menu for configuring system levels pins and also DUT pins . Should it be an Update issue , what are the steps required to performed to resolve this please.
We would highly appreciate your prompt feedback.
Thank you so much.
(1,465 Views)
Do you mean PinMap Editor?
check the list of instruments defined in the PinMap editor and NI MAX, it must match.
Santhosh
(1,455 Views)
Yes, I mean Pin map editor.
It shows in NI MAX but the pull down menu in Pin Configuration Editor does not show all the instruments. Thats the problem.
Any suggestions please?
Thank you
(1,409 Views)
