NI TestStand
Passing parameters to a vi
I have a library of vi's that I would like to use in my test stand
sequence. Instead of redesigning the vi's, can I pass arguments
directly into the controls in the vi? Can I also trigger dialog
buttons from test stand?
I need to set the value in some fields in the vi. Then I need to press
the "execute" button, which will return the error structure.
Thanks in advance,
Brett
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(6,726 Views)
From TestStand, you can't directly pass arguments
into the controls. NI plans to allow this in a
future (distant future) version of TestStand.
In the meantime, you could write some wrapper VIs
that pass data to your controls. You can use the
TestStand API to read/write variables from
TestStand. In the
examples\AccessingPropertiesAndVariables
directory, you will find an example that shows
how to use the TS API.
It sounds like the VI Server vis would work well
to dynamically control your VIs. I'm sure there
must be some examples in the examples database at
http://www.natinst.com/support/epd
You can search or browse this database.
Hope this helps,
Paul Mueller
NI
In article <7oni2t$3tn$1@nnrp1.deja.com>,
brettnick@my-deja.com wrote:
> I have a library o
I pass arguments
also trigger dialog
error structure.
> Thanks in advance,
> Brett
(6,726 Views)
TestStand. In the
Hope this helps,
Paul Mueller
NI
> I have a library o
I pass arguments
also trigger dialog
error structure.
> Thanks in advance,
> Brett
(6,724 Views)
From TestStand, you can't directly pass arguments into the controls.
NI plans to allow this in a future (distant future) version of
TestStand.
In the meantime, you could write some wrapper VIs that pass data to
your controls. You can use the TestStand API to read/write variables
from TestStand. In the examples\AccessingPropertiesAndVariables
directory, you will find an example that shows how to use the TS API.
It sounds like the VI Server vis would work well to dynamically control
your VIs. I'm sure there must be some examples in the examples
database at http://www.natinst.com/support/epd
Hope this helps,
Paul Mueller
NI
> I have a library of
press
> Thanks in advance,
> Brett
(6,724 Views)
