NI TestStand
Passing of arguments to Python script
Working throught the following tutorial i'm comfronted with a problem using the 'Argument Expression' field to pass arguments to a called python script.
http://www.ni.com/tutorial/8847/en/
It has been raised as a topic before (see these 2 links) - but doesn't seem to have been explained/fixed..
https://forums.ni.com/t5/NI-TestStand/Tourbleshooting-passing-arguments-to-scripts/td-p/3099661
https://forums.ni.com/t5/NI-TestStand/Python-Argument-not-passed-through/td-p/3358030
I'm using:
TestStand 2018
Python 36-32
My python script file extension type is correctly associated to the interpreter. But it doesn't pass the arguments ..
Why is this?
(4,253 Views)
correction: TestStand 2016
(4,236 Views)
Sorry to just Jump into your thread like that. I have been working on almost the same project trying to get Data from TestStand to Jupyter Note Book. I have tried to follow the steps from http://www.ni.com/tutorial/8847/en/   but it does not work. when I use the call executable, all I get is a window with my Jupyter code. I don't get any results from theTestStand output window either. Below I have modified the Python code to work in Jupyter.
step #4 of the tutorial
#Get input as a list
numbers = input('Enter numbers: ')
total = sum(int(c) for c in numbers)
print("total_Sum:", total)
Step #3 of the tutorial just reading the data from arguments expression
import sys
#Iterate through each element and get data
for n in sys.argv:
print ("total_Sum:", n)
step# 4Error
I don't think I am pointing tho the Argv data?
total_Sum: C:\Users\rata\Anaconda3\lib\site-packages\ipykernel_launcher.py
total_Sum: -f
total_Sum: C:\Users\rata\AppData\Roaming\jupyter\runtime\kernel-357edb9f-22fb-46ff-91e4-272bc740f56d.json
Is it even possible to access Data through Jupyter?
Any help will be greatly appreciated.
WinnieWanda
(4,146 Views)
