NI TestStand
Passing a 2D array to a code module
When a code module takes a 1D array as an input, it's easy to fill in the element values in the step settings.
However with a 2D array, I can't figure out how to enter the values.
(4,564 Views)
Which adapter are you using?  Have you seen this:
https://decibel.ni.com/content/docs/DOC-21627
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,554 Views)
