NI TestStand
Pass the number of active test sockets to Operator Interface?
Hi all,
Is it possible to extract the number of active test sockets and their index?
So would it be possible to pass information such as
Test Socket 0 = False,
Test Socket 1 = False,
Test Socket 2 = True,
Test Socket 3= True.
Would it also be possible to enable or disable the ability to see the sequence file executing using the information about the Test Socket?
I hope my question makes sense. If not please let me know and I will try to explain it further.
(3,138 Views)
The problem that I have is that if you run 4 UUTs ands then 2 UUTs after you can still see the execution / results of the other 2 UUTs that you are not testing.
(3,123 Views)
Are you using batch or parallel model?
What GUI are you using? Are you using the sequence view controls to display the executions (using tracing)?
Norbert
Expert: Geometry
(3,120 Views)
Using the Batch model.
I am using a custom GUI made with LabVIEW.
To display the executions I am using the sequence file view and the execution view manager.
(3,117 Views)
Are you using multiple sequence view controls? Or only a sinlge one?
Norbert
Expert: Geometry
(3,106 Views)
This might help direct you in the right way: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MVISA2
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,100 Views)
