NI TestStand
Pass a Sequence Reference from calling Sequence to called Sequence
Hello Community,
I have two TestStand Sequences calling each other. Only the second sequence is known. The first one can have any name and be in any path.
The first sequence, let´s call her SeqA, calls a SubSequence, called Test, from the second sequence, I´ll go for SeqB. In the subsequence Test is a call to a SubSequence from the SeqA.
My problem is, that I´m unable to get a reference of SeqA to SeqB for the sequence call.
I already have the Sequence Context from SeqA. I would be very happy, if that would somehow be enough, to get the reference.
I just don´t want to pass two parameters, if not necessary.
Greetings Fred
Message 1 of 10
(5,194 Views)
RunState.Caller.SequenceFile.Path
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 2 of 10
(5,180 Views)
Accepted by topic author The_Fred
If you have to use the sequence context then do something like this:
Parameters.MySeqCtxt.AsSequenceContext.SequenceFile
jigg
CTA, CLA
testeract.com
Message 3 of 10
(5,178 Views)
Good monring jiggawax,
thank you very much for your answers. Both solutions work perfectly.
The "as solution" marked reply is the one I´ll use in my sequence.
I wish you a pleasant weekend.
Sincerely Fred
Message 4 of 10
(5,167 Views)
I'm currently at an almost similar situation and don't see the (maybe obvious) solution:
I'd also like to pass a sequence as a reference to a called sequence. But in my case it is not the calling sequence I want to pass.
Lets say I have two sequences:
1. TestAInputs
2. TestBInputs
Now I have another Sequence "TestVariableInputs" to which I want to pass either TestAInputs or TestBInputs or others in the future.
At the moment I don't see how to generate or select the required parameter-type.
Kind Regards
David
Message 5 of 10
(4,649 Views)
1. TestAInputs
2. TestBInputs
Kind Regards
David
Remember that a sequence context is completely different than a sequence.  You can use an object reference to pass as a sequence.  However, my guess is that's not what you need.
How are you getting references to the sequences?  Are they executing?  If so are they in the call stack?
jigg
CTA, CLA
testeract.com
Message 6 of 10
(4,631 Views)
Hi Jigg,
thank you for your reply.
Oh I was not clean enough. I just want to pass the reference to a sequence, in order to call them in the called sequence then.
In my stated Examle it would look like (as in C):
TestAInputs()
TestBInputs()
And
TestVariableInputs(sequence *pVariableFunc())
Then either call
TestVariableInputs(&TestAInputs)
 *VariableFunc(); // which is TestAInputs() here
or  call
TestVariableInputs(&TestBInputs)
 *VariableFunc(); // which is TestBInputs() here
so maybe Passing a sequence as object reference would be fine, but how can I manage this?
Kind Regards
David
Message 7 of 10
(4,619 Views)
How are you getting references to the sequences?  References to most anything in TestStand can be stored in Object Reference types.
jigg
CTA, CLA
testeract.com
Message 8 of 10
(4,598 Views)
How about something like this: (see attached)
EDIT: I just noticed there was more history to this thread than I thought, so I might be repeating something or not addressing the latest.
Message 9 of 10
(4,592 Views)
Hi James,
thank you, that is exactly what I was looking for. Thank you very much!
Kind Regards
David
Message 10 of 10
(4,573 Views)
