NI TestStand
Parameter information in MSVC++ DLLs
I'm using MSVC++ 6.0 to create DLLs to be called from TestStand 1.0.
When I insert an action into my sequence, select "Specify module...",
choose a DLL, and select the function I want from the drop down list, I
am presented with an error message: "This function does not have
parameter information in the DLL."
I can get the parameter information if I switch to the Source Code tab,
and specify the appropriate file, but I would like to avoid this if
possible.
I've tried in vain to find the appropriate option / switch in the MSVC
project settings, with no luck....
Does anyone have any suggestions???
Thanks in advance,
Jerry
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(5,507 Views)
Jerry,
You can make your DLL with a type library. A type library contains
information about the exported functions and parameters. TestStand can
uses the type library to populate the parameter information. For
example, specify the DLL in TestStand\Examples\Demo\Misc\DLLFuncs.dll.
Follow the instructions at the knowledgebase entry:
http://digital.natinst.com/public.nsf/3efedde4322fef19862567740067f3cc/6
04fdf48c4d9a687862567e5004eb90c?OpenDocument
You can get to the knowledgebase from the www.natinst.com/support/ page
or www.natinst.com/public/
Search for Type Libraries.
Paul Mueller
NI
In article <7sdm6u$egv$1@nnrp1.deja.com>,
jerry_gold@my-deja.com wrote:
> Hi,
> When I insert
I
tab,
> possible.
> Thanks in advance,
> Jerry
Before you buy.
(5,507 Views)
Thanks for your help Paul, but I still haven't quite got it right...
My .odl file is as follows:
[uuid(86DB0EBB-848B-11D3-A474-00C04F34CF6A)]
library IDispatchTest
importlib("stdole32.tlb");
[dllname("IDispatchTest.dll")]
module test{
[entry( "test" )]
void test( [in] IDispatch* test_stand_context );
For completeness, here is my function definition too:
void __declspec( dllexport ) test( struct IDispatch *test_stand_context
AFX_MANAGE_STATE( AfxGetStaticModuleState() );
AfxMessageBox( "Testing 1..2..3.." );
When I build my DLL, and use it from Test Stand 1.0, using the function
test() returns an error message "The parameter information for this
function could not be read. It may contain an unsupported parameter
type." The IDispatch pointer seems to be causing this problem, since I
can change it to a long* in the .odl file, and the parameter
information is successfully read from Test Stand.
Any other hints are much appreciated...
Cheers,
Jeremy
In article <7sp9dl$arq$1@nnrp1.deja.com>,
paulemueller@my-deja.com wrote:
> Jerry,
page
> Paul Mueller
> NI
> > Hi,
module...",
list,
> I
> tab,
> > possible.
MSVC
> > Thanks in advance,
> > Jerry
> Before you buy.
Before you buy.
(5,503 Views)
