NI TestStand
Parallel Model using Multiple Com\Relay Cfgs
I need to test Multiple UUT's that have unique Comport and Relay configurations.It looks like the Parallel Model in Teststand is well suited for this.What needs to be modified to let TS know each unique Comport and Relay configuration for each Test Socket? I'm using Teststand 4.0.1 and Labview 8.6,I'm not using NI Switch Executive.
Regards
JC
(3,114 Views)
You can use RunState.TestSocket.MyIndex as the index to any arrays that hold your configuartion data.
regards
Ray Farmer
Regards
Ray Farmer
(3,104 Views)
