NI TestStand
PXI-8513 CAN card Veristand 2013
2x PXI-8513 CAN cards in a PXIe-1065 chassis. In system explorer I don't see the card, when I try Hardware Discovery Wizard it doesn't find them either. Any tips on how to get these cards to be recognized?
(1,255 Views)
You should post on VeriStand board instead.
Are your PXI-8513 detected in NI MAX?
https://tmesystems.net/
(1,238 Views)
Thanks, no it looks like it is not found in NI-MAX either. This chassis has a lot of cards in it, could it be that PCI resources are exceeded?
(1,205 Views)
What is your NI-XNET driver version?
Are you using an NI embedded controller or MXI system? Is the module detected in Windows Device Manager?
(1,180 Views)
It's a PXIe-1065 chassis with a PXIe-8115 embedded controller in it. I am away from the system today but it has a NI-XNET version installed at the same time as Veristand.
(1,149 Views)
