NI TestStand
Operator interface Entrypoint through Digital IO (DIO)
I need to Start, Stop, Abort the Teststand Simple Operator Interface with  Hardware  Switches
Issues is to connect the ActiveX  Controls(Entrypoints) with the H/ W  Switch  read thr´ DIO
The teststand Entrypoint  Buttons are Active X  and they dont let value signalling  or any other method to let  Interact with the Teststand Engine.
Has any one worked on the same.
Any NI notes for the same!
regards
akshay
(4,258 Views)
As an example, the Test UUTs entry point button is connected with:
                this.axSequenceFileViewMgr.ConnectCommand(this.axEntryPoint1Button, CommandKinds.CommandKind_ExecutionEntryPoints_Set, 0, CommandConnectionOptions.CommandConnection_NoOptions);
The way to invoke the same action as it will invoke when pushed is:
               this.axSequenceFileViewMgr.GetCommand(CommandKinds.CommandKind_ExecutionEntryPoints_Set, 0).Execute(true);
(4,252 Views)
Hallo James,
thnks for the response
Tried this method   alas always get Invalid index error
I use labview as my  development enviornment
(4,231 Views)
Hi James,
unfortunately the mthd doent give expected response
(4,184 Views)
