NI TestStand
Offline Results Processing - NULL error
Good evening to you all,
I have an issue trying to use this tool and I was hoping that someone can help me. The problem is that Offline Results Processing continue to show this error:
This happens every time I try to process a file previously saved with Offline Results File option. This are the settings:
Teststand is the version 2014 SP1 (64bit) on windows 10 PC. Any ideas?
Thank you very much,
Francesco
(1,524 Views)
Hello Francesco,
You have mentioned that you are trying to use a tool, which tool do you want to use?
(1,476 Views)
Hi  lyudvig.h,
By tool I mean the NI TestStand "Offline Results Processing Tool". Sorry if I explained myself so badly.
Francesco
(1,465 Views)
Hi MATA82,
I have found a solved forum post, which may be helpful in this case. Try to go through that post.
Regards)
(1,336 Views)
