NI TestStand
Observing the different data on NI Bus monitor when we open the same software from different way.
Observing the different data on the NI Bus monitor when we open the same software from different methods . Means if I open the Bus monitor from the NI max ( NI max>> CAN Bus>> Bus monitor) and open directly from the search window (Search window>> Bus monitor) observe the different data on the both Bus monitor screen. So I am confused about which data I have to use. observing the different messages on the bus monitor. Ex. I have 100 messages, so on bus monitor1 observe 1st 20 messages, then 30 messages are observed on the 2nd Bus monitor, and the remaining 50 messages are not present on any of the buses. And the important thing is observing wrong data on bus. Could you help me with what I can do?
(339 Views)
You might be more successful getting an answer asking your question here:
https://forums.ni.com/t5/Automotive-and-Embedded-Networks/bd-p/30
(332 Views)
