NI TestStand
Not able to read "Result.Numeric" Property.
Hi all,
Am reading the propeties of step using C# as follows
SequenceContext
seqctx = e.uiMsg.Thread.GetSequenceContext(0, outframeid);
if(seqctx.PreviousStepIndex >= 0)
Stepprvstp = seqctx.PreviousStep;
StepTypeprvstptyp = prvstp.StepType;
PropertyObjectstepPropertObject = prvstptyp.AsPropertyObject();
string[] SteptobeinStatus=null;
if (string.Equals(prvstptyp.Name, "NumericLimitTest"))
StringstpName = prvstp.Name;
StringstpDesc = prvstp.Description;
double lwlimt = stepPropertObject.GetValNumber("Limits.Low", 0);
double measValue = stepPropertObject.GetValNumber("Result.Numeric", 0);
String unit = stepPropertObject.GetValString("Result.Units", 0);
double hglimt = stepPropertObject.GetValNumber("Limits.High", 0);
String resultstatus = prvstp.ResultStatus;
am able to get High and Low Limits and the Result of the step but am getting empty value when i access Numeric and Units property.
can some one please help me with get the velue
Thanks in advance
IVI
(3,123 Views)
Are you perhaps access the properties before they are filled in? Are you sure the step executed?
-Doug
(3,110 Views)
Thanks for your quick response.
i found the solution.
i need to convert "Step: as an property object not the "StepType".
IVI
(3,099 Views)
Ah yes, sorry I missed that. I should have looked at the code more carefully.
-Doug
(3,093 Views)
