James,
> I think tool menu items are run with the ExecTypeMask_InitiallyHidden
> and ExecTypeMask_TracingInitiallyOff flags passed to the
> executionTypeMaskParam parameter to Engine.NewExecution. Thus tool
> menu executions don't appear in a window unless you hit a breakpoint.
> In a simple tool menu sequence, I added a statement step with the
> expression RunState.Tracing = True. This caused the window to appear
> so the progress indicator and report are visible.
Thanks. I forgot to mention that I'd tried that... still no luck. I added
the RunState.Tracing = True as a statement as the first step in my Tools
seqeunce call. The execution window still does not appear. Is there some
place special this statement needs to be?
Are there any global setting
s that override the Tracing flag? If I check
Enable Tracing in Station Options, while the window pops up, the execution
takes unacceptably long as TestStand traces every single step, even when
tracing speed is set to max. I can't find any other setting that seems
related to this...
Any other ideas?
Bob
Etec, Inc.
