NI TestStand
No access to python function in for loop
Hello
within teststand (2020) I am calling a python function. This function is running without a problem when calling several times directly from the python IDE. Now when I call the same function in a teststand sequence within a for loop, it works but on for the first loop. The second and following loops are failing with the error message:
<class 'IndexError'>
list index out of range
When I unload all modules after the first loop then all other loops are working without any problem. What could be the reason for it and/or is there a better solution?
Thanks in advance
(1,590 Views)
Norick17,
I am unable to reproduce the issue. Please provide the sample files for which issue exists.
-Shashidhar
(1,558 Views)
let me ask differently:
When you instantiate a python class you get an object reference inside the "Variables View". In my case I use a reference in the local variables:
When you click on the scissor you can release the object again. Is there a way to programmatically release the object reference with Teststand??
(1,546 Views)
Accepted by topic author Norick17
Using TestStand expressions (like in Statement step), update the object reference so that it does not hold any data. You can do it with an expression like:
Locals.SPI_Interface = Nothing
Executing that expression is equivalent of clicking the scissor icon next to the variable.
-Shashidhar
(1,544 Views)
