NI TestStand
Need help with Test Stand Logic Formula
I have:
Locals.TestBool = (Locals.Value != (1||2) ? True: False)
When the value is 1, it returns False.  But if the value is 2, it returns True.  Does that not work as I expect?  Not a traditional OR?  Am I missing something?  Is that not actually saying If Locals.Value Does NOT Equal 1 OR 2, then True?  Why does it return false for only 1?
(1,448 Views)
Accepted by topic author DailyDose
|| causes a Boolean OR.  1||2 will result in a TRUE.  Now that TRUE has to be converted into a numeric to compare to your number, which will be a 1.  So 2 does not equal 1, therefore your result is TRUE.
What you really need here is:
Locals.TestBool = (Locals.Value != 1) && (Locals.Value != 2)
With this setup one of the intermediate values will be a FALSE if Value is a 1 or a 2.  You need to then AND those values to get the result you want.
GCentral
(1,414 Views)
Ahhhh.... Thank you!   This feels like a newby mistake.  Much appreciated.
(1,376 Views)
