NI TestStand
.NET assembly requires app.config file, can't find it when called from TestStand
I have created an assembly that uses SubSonic (a DAL creation tool - http://www.subsonicproject.com).  It works just fine.  I can create (.NET) applications that access this assembly (provided I setup their app.config correctly).  All is good in the world.  Unfortunately, the primary use of this assembly is that is is called from TestStand.  I can call any functions in the assembly and they all work EXCEPT when the assembly tries to hit a database.  Here is the exception that gets thrown:
The .NET method 'StoreTestResults' threw an exception.
Can't find the SubSonicService section of the application config file
Source:  SubSonic   at SubSonic.DataService.LoadProviders() in C:\svn\subsonicproject\trunk\SubSonic\DataProviders\DataService.cs:line 196
   at SubSonic.Select..ctor() in C:\svn\subsonicproject\trunk\SubSonic\SqlQuery\Select.cs:line 41
   at DAL.DC4DAL.StoreTestResults(SequenceContext seqContext) in C:\Projects\ProductionTest\Main\Source\Main\Source\DAL\DAL\DAL.cs:line 95
I have done a lot of searching, and the only solution to this I have found is to create an app.config file for the application.  Unfortunately, TestStand does not have an app.config for me to modify, nor did creating a new one (with the names app.config, SeqEdit.app.config, or SeqEdit.exe.app.config) solve the problem.  So, how do I get this to work?  The DAL needs to read the connection string and other information from the .config file.
(5,735 Views)
Hi rcldesign,
Your attempts were very close to creating the config file correctly. I went to www.ni.com and entered "teststand config" in the search field and found a KnowledgeBase article that explains how to create a config file for TestStand.
How Can I Force TestStand to Use a Version of the .NET Framework Other Than Version 2.0?
Basically all you need to do is name the file SeqEdit.exe.config and place it in the <TestStand>\Bin directory.
Manooch H.
(5,705 Views)
