NI TestStand
Multiple versions of TestStand (2013 and 2016)
Are there any issues with having multiple versions of the TestStand development environment installed on my development computer? Thanks.
(3,554 Views)
Accepted by topic author stephenb2
Hi stephenb2,
There are no problems with having multiple versions of TestStand installed. There are a couple things to keep in mind though.
Only one version of the TestStand engine can be active at a time. Use the TestStand Version Selector to change the active version. Sequence files made in TestStand 2013 can be opened in 2016, but not vice-versa (although you can save as a previous version if you need to). Finally, you will have seperate directories for each version, so make sure you know which directory/version you are working in.
Hope that helps!
Steven Gloor
Staff Customer Engineer - CTA, CLD
(3,545 Views)
