To McGregorMortis -
A substep is a subcomponent of a step type. Step types definitions can reside in a type palette file or any sequence file. When a sequence file uses an instance of a step type, i.e. a step, the step type definition is attached to the sequence file.
We specifically decided not to use the current sequence file search path for substeps in step types for the following reason:
A step type only loads the substep code module
once, even if more than one sequence file uses
it. So if one sequence file has the code module
for the substep in its directory and another
sequence file has another copy of the code module
that might be a little different, the second code
module would not be used.
Step types ar
e intended to be used as a major component of the TestStand engine. That is why the default TestStand step types are stored in the Components directory and the search directory feature specifies to recursively search the Components directory.
Hope this helps...
Scott Richardson (NI)
Scott Richardson
https://testeract.com
