NI TestStand
Message POP UP
I have a problem with message POP UP. I have some sequence written in TestStand and after an error occured, I am informed of error by message popup. There is a way to show information of this message in LabView? Like between two .Vi using a vi server?
(3,639 Views)
If you'd just like the popup not to occur, then you can change the station setting- Configure » Station Options » On Run-Time Error- to something like "Run Cleanup", then just get the error information after the execution is complete.
If you actually need this error information immediately at runtime, there are a few ways to do this. Both of the ones that come to mind require customizing your operator interface:
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(3,602 Views)
Tanks for reply, but I only have Operator access to this application from test stand. I only know in which file this message popup is. My only tool that I have is LabView 2011, I thought this may work like VI Server in LabView but now I think is not. I read about this in internet and I found that reference named Sequence Contax is a key to do this, but I don't have access to create this. Can you help me?
(3,573 Views)
Hello there
Could you explain it a little bit more, why do you need to show the error in LV?
Regards
Ambrus
Technical Support Engineer
??It's just business ??
(3,537 Views)
Application show error in Message POP UP that occur in sequence from Test Stand, this is just a message with string maybe some boolean control, and I need to get this string and click boolean control.
(3,535 Views)
I think this question is coupled with this one. Is that correct?
Anyhow, i think you miss some basic knowledge about TS. Which NI trainings regarding TS where you able to attend?
Norbert
Expert: Geometry
(3,527 Views)
