NI TestStand
Merge sequence and its steps tables
TestStand creates separate tables for the sequence and its steps:
Is it possible to merge them somehow?
Thank you!
(1,044 Views)
You can have a look at this example :
C:\Users\Public\Documents\National Instruments\TestStand 2021 (32-bit)\Examples\Customizing Result Processing\Model Plugin - Basic Step Time Report
Run the install sequence which will add a new result plugin.
Select this report type from configuration menu.
This will give you report in excel format with results in consecuitive rows.
Formatting the existing report may require more effort.
Ravi
(1,008 Views)
