NI TestStand
MatrixCode read using .net
Hello.
I'm trying to decode a Picture (get it from WebCam) matrix code using the .net module in TestStand.
but it's my fist time using this .net Module.
I'm using test stan with LabView module, but the licence for vision pakage is too expensive and I'm going to put this Sequence in 4 testers.
I annexed the .net/dll than maybe work and a picture.
I can provide the Picture as a file or an array of numbers (24-bit pixmap from "Unflatten Pixmap" VI in Labview .
Please change .txt ext to .dll        in BarcodeLib.BarcodeReader file
(5,364 Views)
do any body has a diferent .NET or DLL library to decode Data Matrix?
(5,345 Views)
here different pictures...
(5,282 Views)
Hello Luis,
Thanks for using the NI forums! You can find my reply in the following link:
http://forums.ni.com/t5/LabVIEW/Read-MatrixCode-using-NET-or-dll/m-p/2705499#M803110
Regards!
Luis C.
Ingeniería de Aplicaciones
www.ni.com/soporte
Luis CT
(5,270 Views)
As for me, I am testing the related data matrix barcode scanner software these days. Do you have any ideas about it? Or any good suggestion? I am totally a green hand on barcode generating field. Any suggestion will be appreciated. Thanks in advance.
Arron
(5,001 Views)
