NI TestStand
Localization - Accessing Language Property
Is there a function (preferably in LabWindows/CVI) that will allow me to get (read) or set (write) the language property setting (i.e. "English", "Spanish", etc.) of TestStand. I would like access to this property so that I can compare it to the language setting of the PC and verify that they are the same. If these settings are different, I would like to be able to set the TestStand language property to the same setting as the PC.
Thank you in advance for your time and assistance.
Thank you,
Jim
(3,157 Views)
Jim -
You need to access the StationOptions.Language property of the TestStand engine. The wrappers for CVI will have this property as TS_StationOptionsGetLanguage and TS_StationOptionsSetLanguage. Changes to this property do not take effect until the next time you start the engine or call Engine.ReloadStringResourceFiles.
Scott Richardson
https://testeract.com
(3,146 Views)
