NI TestStand
Load a sequence file using the LabVIEW API (no dialog)?
I am creating a custom LabVIEW UI and I would like to pass in the path of my main sequence using the LabVIEW API. All the examples that I have found have TestStand set the sequence through a file dialog. Is there a way to do this without the dialog?
(1,500 Views)
Accepted by topic author al_g
(1,434 Views)
I did get it to work using the GetSequenceFileEx method basing my code on the "Execute With No Process Model.vi". I don't know if I would say it was "No big deal"
(1,419 Views)
