Hello
Check out the following
link.
If you are concerned that you will end up distributing alot of UIR files that are not in the same folder as the executable, you can embed the UIR's into the executable by using the UI to Code Converter tool, located in the project window under Tools >> UI to Code converter. This way, when you distrbute the app, you will only have one executable to provide, not a UIR and exe.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
