NI TestStand
LabView context help appears at runtime
We've seen in some instances, the context help (for our LabVIEW VIs) appear during some of our TestStand testing.  This (in the final product) is undesirable.  Is there a way to ensure (when running the test executive - operator interface) that the Context Help is disabled?  I saw a thread out in the LabVIEW forum that showed how to capture the Ctrl-H event.  I am using a customized TestStand HMI, but if the context help is disabled to start with, the end user (not familiar with LabVIEW's shortcut keys) would most likely not try a Ctrl-H.
(3,103 Views)
Hello mrbean,
I'm not quite sure if this is the discussion forum you saw, but the disable context help discusses a similar issue.  This is something you can setup programmatically LabVIEW and it also discusses how to remove the crtl-H/h situation as well.
Another way to address this situation would be to:  File>> VI Properties>> Window Appearrance>> Change to Top Level Application Window.  Click Ok, now when you run the VI the Context Help Box goes away on the front panel.
A_Ryan
AES
(3,083 Views)
