NI TestStand
LabVIEW Simple operator interface deployment
Hi All,
I try to deploy a TS 3.1 application with a LV 7.1 Simple OI. I successfully (no errors) built the OI executable and created an installer with default options. I also built the Deploy TestStand System and created an installer with default options, except I selected only User Interface->Simple->Labview (no development system). I installed them on the target machine without any problem. The problem appeared when I ran the OI; it reported "Error 97 occured at Unknown System Error in TestStand-Set TestStand Application Window.vi->Simple OI-Top-LevelVI.vi. Possible reasons: Labview: Null Refnum was passed in as input".
I beleive this happened because the "Application Manager", "SequenceFileView Manager" and "ExecutionView Ma
nager" ActiveX Controls, which were required by the OI, were not present on the target PC.
Obviously, TestStand Deploy did not distribute them.
Does anybody know how to distribute these ActiveX controls or have a successful experience of distributing the LabVIEW Interface?
Thanks.
(3,245 Views)
PPascal,
We've seen this error before, and it usually fixed by a simple reinstall. You could also possibly just run a repair on the TestStand engine within add/remove programs and this should also fix the problem. Please try this and post back if this does not fix the problem for some reason. Thanks and have a good one.
Adam B.
(3,245 Views)
