NI TestStand
LabVIEW Operator Interface Calling TestStand Sequence Issue
Hi there,
Anne here. I currently have a project that uses LabVIEW as the main Operator Interface and it calls TestStand and runs the sequence that was selected. In development mode, I am able to call the sequence with no problem but once I make the operator interface into an executable, I can see that it was able to communicate to TestStand since it was able to have the login promt but when I run the test sequence, it was not running the test sequence. Is there any special consideration that I have to look into when calling teststand sequences in an executable operator interface?
Thanks!
Cheers,
Anne
(3,198 Views)
What do you mean by not running?  How are you starting the sequence? Single Pass, Test UUTs, Run Sequence?
PH
(3,188 Views)
