NI TestStand
Is this a proper way to add session in NI PXIe-4143 (NI Dc Power)?
I am new to NI Teststand. While adding a new session on Ni DCPower I am getting a error "Instrument cannot be found" I have attached the error and the function for adding the session.
But the instrument is correctly named as per NI Max and is installed.
I am using Ni Teststand-2020.
Could someone help what could be the problem here?
(1,019 Views)
Probably you should ask this on the following forum :
https://forums.ni.com/t5/Digital-Multimeters-DMMs-and/bd-p/80
From the error it seems the drivers are not corectly installed.
Can you check from MAX if there is a way to control the device and check if it works correctly.
Can you run some example programs associated with this device.
Ravi
(993 Views)
