NI TestStand
Is there any way to configure TestStand to use Labview 6.1?
Guys
I´m working with evaluation TestStand Version 4.2.1 to update a Labview system and found that Labview version should be greater than 7.1 but my old Labview register version is 6.1. Is there any way to configure TestStand to enable use Labview 6.1?.
Test Design Engineer
ALU Mexico
(3,464 Views)
HI Elchampinion, as you mention the TestStand LabVIEW adapter only supports LabVIEW 7.1.1 and later. This doesn't allow you to call the VIs directly, the only option you could try is creating a DLL from you VI and call the DLL using the C adapter, that way you shouldn't  have the compatibility problem.
Still my recommendation in this case is update your LabVIEW License, so you can get all the new options that LabVIEW provides. You can contact the sales department in Mexico the phone  018000100793, for a quote on the upgrade, and you can download a free trial of LabVIEW from:
https://www.ni.com/en/support/downloads/software-products/download.labview.html
 Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
(3,440 Views)
HI,
Yes it is should be possible without buying new Software.
(I have currently no TS4.2 on my private maschine, so it could be still different)
On the TS LabView adapter there is an option for TeststandLVRTE
You have to select this.
This link to some answers from Ray should solve your task
http://forums.ni.com/ni/board/message?board.id=330&message.id=21975&query.id=99588#M21975
hope this spend some money Smiley Wink
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,431 Views)
