NI TestStand
Is there a way to print out the seq file (main,setup,cleanup,...)
I just wanted to have a paper copy of the Seq file that were created. Thanks.
(3,532 Views)
You can select Tools->Sequence File Documentation from the Sequence Editor menu. This will produce a report in HTLM or text that describes each of the steps in the setup, main, and cleanup sections of each sequence. It may be more information than you were expecting, but it is information you would need if you were to reproduce the sequence file from the documentation.
Mark Ireton
(3,532 Views)
thanx i will see how much info is created in the report file
(3,532 Views)
You can capture the sequence editor with your sequence loaded by Alt-Prnt Scrn and then paste it into a word document. I've used this from time to time.
Regards
Ray Farmer
Regards
Ray Farmer
(3,532 Views)
