NI TestStand
Is there a way of passing data between vis running concurrently in 2 seperate teststand sequences?
I have a vi which i want to execute in a teststand sequence and then call another vi in a separate sequence, running in parallel. Is there a way of dynamically passing data between the two executing vis?
(3,360 Views)
Accepted by topic author DP2
Just realised i can still use FVGs between the two sequences.
(3,357 Views)
You can use different methods including: FileGlobals (if the two sequences are from the same sequence file), StationGlobals, Shared variables, Network communications (network stream (TCP))...
Rodéric L
Certified LabVIEW Architect
(3,355 Views)
