NI TestStand
Integrate TestStand 4.0 with Clearcase
Hello
My concern is regarding the integration of teststand with clear case.
I am a new user to test stand and want to build up a workspace in which i will be adding different sequences as per requirement.
So, i need to know that how do i integrate this workspace with Clearcase so that i can checkin the updates.
Hoping to hear from you soon.
Please let me know if you need any other information.
Regards
Nitin
(3,145 Views)
Hello Nitin,
There is a small section about which source control software TestStand 4.0 has been tested with in the TestStand Reference Manual (for version 4.0).  Rational ClearCase is one of the programs on that list, which means that it should work nicely with TestStand.  If you need help with specific aspects of the integration I would check in the TestStand Help since it addresses particular configuration options in detail.  This information should covere the basics and be enough to get you started. Feel free to post again if you run into any specific problems.
John B.
(3,113 Views)
