NI TestStand
Integrate Labview Subvi with runtime
im trying to integrate the attached subvi in TestStand (2017 64 bits), using only the runtime engine in the PC,  but im getting all the time errors or it is not working correctly.
I would appreciate any idea or help,
thanks so much in advance!!
(2,312 Views)
So the run-time setting requires that your VI be able to run with the run-time engine.  In order to make a VI able to run with the run-time engine it needs to be compiled and linked to it's dependencies properly.  If you look at the VI Hierarchy Tree of your VI you will notice that it requires a lot of subVIs as dependencies (this includes all of the VIs from vi lib, etc...).  There are several ways to get your VI into a "run-time" state.
1- use the TestStand deployment utility to deploy it
2- put it into a PPPL (packed project library) and call the PPL from TestStand
3- Create a source distribution and this will re-link and copy all of the subVIs over
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,262 Views)
