NI TestStand
Inernet Explorer error when setting report options to xml
I get an error message stating that I need ot upgrade my ie to version 6 when I try to set reporting options to xml.  The ie version on the PC is 6.0.2900.2180....
Has anyone had this problem?
(3,745 Views)
Hi
What is the value of the following registry key on the computer that has the above behavior?
Key - HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Version Vector
Subkey - IE
Regards
Anand Jain
(3,646 Views)
Anand,
there is no Subkey - IE in the registry.
(3,638 Views)
Bill
To clarify you have the Key - HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Version Vector but no IE value?
This key should be set by IE when it was installed.
A fix to your problem you could add a string value called IE with the value of 6.0.
I have some questions to understand how the machine got into this state -
1. How was IE installed on this machine? Windows update, IE CD?,
2. Was this machine upgraded from previous version of windows? I found a post on MSDN stated that there is an IE bug - if the machine was upgraded from Win98 this key will not be set.
3. A screen shot of IE's about box
4. Was there anything different about how your machine was setup? Was it a clean XP SP2 install? factory installed? etc
Regards
Anand Jain
(3,635 Views)
Anand,
thanks for the help.
Regarding your questions, I found the key to be missing on 3 computers.  One was a Dell Laptop with factory installed XP pro and the other 2 were Stealth computers (rack mount) also with XP pro from the factory.
The computeres are on our network and get updates regularly, so I do not know if the updates had anything to do with the problem.
Screenshot of IE is attached (.bmp)
(3,621 Views)
