NI TestStand
Including a LLB into the Teststand search path
Hello everyone,
on a testsystem I am using Teststand 2013 and Labview 2013. There are different measurement instruments in my system and right now I have all the VIs for controling these instrumtens saved as VIs on my system. Now I want to change this into an LLB. But when I do that, Teststand is no longer able to find the VIs inside the LLB, although the LLB is in the serach path of Testand. Since a lot of Sequence files access these VIs, it would be a lot of work to manually edit each VI call. Is it possible to include the LLB into the search path?
Thank you very much for your help!
Felix
(4,554 Views)
The search within a LLB is not supported within TestStand.
You need to update your vi path in the step settings like "MyLLB.llb\In An LLB.vi"
i.e. modify the path as  llbname\\existingviname.vi.
If you put the llb in a relative path it should be fine.
Ravi
(4,495 Views)
