NI TestStand
Importing variables from .csv to be used to set channels and perform channel value limit test
Is there a way to import a file like the one attached and loop through each row as opposed to creating a step to set each unique value and to check each unique limit?
(2,966 Views)
Accepted by topic author hdonovan39
Hey,
This is actually a perfect candidate for the Data Streams feature that was introduced in TestStand 2017. If you haven't upgraded to the TestStand 2017 SP1, you can download it at TestStand 2017 SP1 - 64 bit and take a look at the shipping example for data streams at <TestStand Public>\
Examples\Fundamentals\Using Data Streams\
Thanks!
Roxy
(2,962 Views)
