NI TestStand
Import table in Excel into TestStand array variables?
I'm trying to use the property loader to read in an Excel file and create a number of local variables.  The tables that I maintain in Excel are of the following format:
Range Setpoint High Limit Low Limit
5 -4.5 -4.49395 -4.50605
5 0 0.0011 -0.0011
5 4.5 4.50605 4.49395
250 -225 -224.6975 -225.3025
250 0 0.055 -0.055
250 225 225.3025 224.6975
 From this table I want to create 4 local variable arrays in TestStand, all 6 elements deep: Range, Setpoint, HighLimit, and LowLimit.  Is there an elegant way to do this without having to use all the formatting syntax that would be in a generic export of these locals from TestStand to an Excel file (i.e. using the method of export Excel file, fill in your own values, then import the Excel file)?
(5,994 Views)
I've only done it in exercises, but you should be able to use a property loader step to your local variables. You can choose from a few different file formats.
StephenB
(5,962 Views)
To rephrase my issue, I want to be able to store my Excel file data in style of table from my first post and not like TestStand's "preferred" formatting as shown here:
IFTDCVInputStart
<Step Name>
<Locals> Variable Value
HighLimit <Prop Name='HighLimit' Type='Array' LBound='[0]' HBound='[5]' ElementType='Number'><Value ID='[0]'>-4.49395</Value><Value ID='[1]'>0.0011</Value><Value ID='[2]'>4.50605</Value><Value ID='[3]'>-224.6975</Value><Value ID='[4]'>0.055</Value><Value ID='[5]'>225.3025</Value></Prop>
LowLimit <Prop Name='LowLimit' Type='Array' LBound='[0]' HBound='[5]' ElementType='Number'><Value ID='[0]'>-4.50605</Value><Value ID='[1]'>-0.0011</Value><Value ID='[2]'>4.49395</Value><Value ID='[3]'>-225.3025</Value><Value ID='[4]'>-0.055</Value><Value ID='[5]'>224.6975</Value></Prop>
Range <Prop Name='Range' Type='Array' LBound='[0]' HBound='[5]' ElementType='Number'><Value ID='[0]'>5</Value><Value ID='[1]'>5</Value><Value ID='[2]'>5</Value><Value ID='[3]'>250</Value><Value ID='[4]'>250</Value><Value ID='[5]'>250</Value></Prop>
Setpoint <Prop Name='Setpoint' Type='Array' LBound='[0]' HBound='[5]' ElementType='Number'><Value ID='[0]'>-4.5</Value><Value ID='[1]'>0</Value><Value ID='[2]'>4.5</Value><Value ID='[3]'>-225</Value><Value ID='[4]'>0</Value><Value ID='[5]'>225</Value></Prop>
<FileGlobals> Variable Value
<StationGlobals> Variable Value
IFTDCVInputEnd
(5,945 Views)
have you ever thought about doing this with SQL-Step Type?
When using this you are compelty free of desgining you table.
The only disadvantage is that you need at least 5 steps to this.
1.) Open Connection
2.) SQL Statement.
3.) Loop that fills your array
4.) Close SQL Statement
5.) Close Connection.
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(5,868 Views)
