I am trying to replace the operators interface's sequence file dialog box. I am also trying to hide the standard operators interface.
What I am after is to replicate a user experience!
Teststand is being used to replace an ATE written in LV where each of the tests are hardcoded in. The user selected the product and test types from a button based dialog boxes.
I am using TS to overcome all of the limitations of the original ATE, but one of the requirements is the system has to have the same look and feel of the original.
I originally though that I would have to modify an operators interface, but I would prefer not too, and would rather change the process models and use engine and station callbacks.
If I have to change an operatos interface, I would pre
fer if the changes didn't affect the normal running of standard TS sequences.
I have attached the process model, i am trying to achieve, (its in Visio).
Tim
