NI TestStand
I am trying to debug HTBasic code modules while using Test Stand, how do I refresh the subs that have been loaded in memory?
I am writing an application for Test Stand, we are using modules previously written in HTBasic. Whenever I make a change to the code and try to re-run the program, it just runs the old version of the code. The only way to refresh the code is to close Test Stand down and restart it. Is there a way to flush the memory of modules?
(3,262 Views)
I haven't used HTBasic with TestStand 2.0.x, but I'm assuming that you have the steps in the sequence set to unload when sequence file is closed (look under the step properties -> run options tab).
If you're still prototypeing, use the File->Unload all modules option. Have a look at page 4-3 in the user manual - it refers to .DLLs, but I'm assuming the HTBasic falls into the same methodology.
Altering the run options from it's default will affect the memory useage and speed of execution of the test sequence. Have a look at page 5-22 (page 158 in the .pdf) in the TestStand user manual - basically, if a code module is loaded into memory already, when the step gets to execute, the loading overhead is already done. If it stays in memory after this, then it's avail
able for next time (quicker second run 'cos it doesn't need to load again. However, the balanceing factor is the sequence is useing more memory at a time, by haveing the module ready.
My usual setting is to use Load dynamically, and Unload after sequence executes. I use this is only during development however, as this is not the most speed friendly, but a compromise so that if I don't call a step I don't load it, but if I do use a step, I'm sure it's free again when I need to modify the .dll modules I create. If you have a look on page 5-7 (143) of the user manual you can set the sequence file to effectively over-ride each step's load and unload settings - useful if you want to revert back again later. If you use this, you'll see that the top two run options for the step are greyed out, but if you set it back with the sequence file options, they do revert back to their original settings.
Hope that helps (and works!!)
S.
// it takes almost no time to rate an answer Smiley Wink
(3,262 Views)
